Код:bitrate address 10 mbps 0x4120 12 mbps 0x4140 16 mbps 0x4170 18 mbps 0x4190 20 mbps 0x41A0 25 mbps 0x41C8 30 mbps 0x41F0 35 mbps 0x420C 40 mbps 0x4220 45 mbps 0x4234 50 mbps 0x4248 60 mbps 0x4270 70 mbps 0x428C 80 mbps 0x42A0 100 mbps 0x42C8 120 mbps 0x42F0 150 mbps 0x4316
Ждемс.
